- Device model: iPad Air (2024)
- Version of operating system: iOS 17.6
- Version of djay: EDIT: 5.2.1 not 5.1.2
- Hardware/controllers used: Xone K2
- Configured MIDI action “FX 1 Enabled” MIDI Out
- Enable FX 1 in UI (MIDI output message (data: 127) sent correctly on MIDI channel)
- Change assignment of FX1 (e.g. from Deck to Percussion)
Expect: no new MIDI output message on MIDI channel configured for FX 1 Enabled.
Actual: MIDI output message data: 0 sent on MIDI channel configured for FX 1 Enabled.
This has the effect of turning off the light on the button configured on the Xone K2 for FX 1 Enabled, despite FX 1 still being enabled.
Hi @wasabidj, thanks for the details about your setup and the issue. To clearly communicate this to our engineering team, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Thanks for the video @wasabidj, this is very helpful. Can you please confirm that you are using djay 5.1.2 and not 5.2.1? I was able to reproduce this on djay 5.2.1, but wanted to confirm we are on the same version. Thanks! Also, I have forwarded everything to engineering for review and comment. I’ll report back when I have news.
Yeah - sorry that should read 5.2.1!
