FX pack for windows Djay pro. Can it be reloaded on my other computer?
Hi
I bought windows DJAY Pro/Spotify and the FX pack separately for my touchscreen laptop on the Microsoft store and after a month decided to also install Djay pro on my bigger touchscreen 23’’ computer.
I go to windows store to get another download of Djaypro free of charge, no problem but the FX pack is not showing !?!
Do I have to buy the FX pack again for my second computer?
thanks.
the FX pack should be accessible for your account, have you checked if you can access all FX directly in your djay Pro version?
Thank you in advance.
Cheers,Lukas E.
