FX pad lock/unlock
(copied from a previously closed suggestion from 2017)
Would be good to lock/unlock the FX PAD finger position so that we can lift up our finger and the effect will stay in place.
Hi @andyscuff,
Thanks for bringing this suggestion to the community again!
I’ve updated the ticket for this feature request and have passed it over to our dev team for further consideration.
Looking forward to your next great post!
This would be an awesome feature!
So many other apps have it.
It’s much easier the dial-in the sweet spot based on when you apply the filter inside the beat from an XY pad then it is to manually knob it it.
Often it takes a few tries to start the effect at the proper time. With a lock it’s touch and go, done!
:pray:t4:
