When loading a new track, and having “reset EQ, FX Tempo” enabled in the settings, the FX on/off status is reset, but the FX parameter is not reset. ie. with “dub-echo” the default parameter setting is 3/4, and when loading a new track it will turn to OFF, but when you have f.e. set to 2 or 4 it will not reset to 3/4. Dunno if this is as designed, but I would expect that the parameter setting would also be reset. Or maybe it can be an optional (sub)setting
- Device model (e.g. 2020 iPad Air 4th Gen): Macbook Air M4 16GB RAM
- Version of operating system (e.g. macOS 14.4.1): Tahoe 26.4.1
- Version of djay (e.g. 5.1.2): 5.6.4
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Reloop Mixtour (non-pro)
- Hardware firmware version (e.g. 1.0.1): na
C) EXPECTED RESULTS:
D) ACTUAL RESULTS:
