fx twist permenent
Hey everybody. Can anybody helps me? I’m trying to get know how to mantain some instant fx permenent with no need in keeping touching it. Therefore I can play with the eq in the same time…
Ty
Hi Adam,
are you using an external controller besides your iPad?
Hi Adam Hey,
you can set a permanent fx by going to FX -> Manual -> Slider, now you can activate a FX permanently by clicking the “ON” button.
Hi Adam Hey,
I see where your problem is. Unfortunately the instant FX’s like the “Twist” can not be used permanently in djay 2.
This can be done by using djay Pro by press holding the “TWIST” and going to the Equalizer section with your other hand.
Hey Lukas,
Nope , I’m using just the app on the iPad with no console. I noticed that sometimes the app sets the instant fx permenent, so I don’t need to keep my finger on it and I could fix the eq in the same time while the fx was running (ps. I’m talking about the the twist fx) the only problem is that I don’t know how that happened …
Thanks for the help
Hey again, the thing is that for the “twist” fx there is no manual option…
Thanks for the help. Anyway sometimes it works also with djay2. Perhaps there is some sort of bug.
Thanks again.
