FX usable for Loops?
Hello, I would like to ask if it is possible or planned that FX can be applied to individual loops or loop sections?
Thank you for your support!
Hi there, if you are using loops in a deck then yes you can use effects. Or are you referring to the looper?
I meant the looper, yes!
Hi @Edgar_Z,
Thanks for sharing your question!
At this time, FX cannot be applied to specific loops in the looper. However, we can share this with our engineering team for further review.
Could you maybe share some additional details and/or the use case?
Many thanks for your reply! I think it would be a great improvement if loops could be mixed in the looper not only with the help of “Stop & Play” and the volume, but also if rooting the effects could be applied to individual areas of the looper section. In my opinion, this would be a useful extension of live mixing in Djay Pro. I really hope for an upgrade in this direction!
