FX volume separate from track gain?
the volume of the fx is a bit quiet. I thought that if I turned the track gains down then FX might be louder. Is that how it would work? or is there another way to have louder FX? for example a riser FX.
Hi @Nubium, try adjusting the W/D knob for each FX.
Thanks for your input. That is just the dry, wet controller, it’s not the actual volume for the effects. On my other djay mixer, for example there is Separate control for riser volume. I guess this is normal on DJ controllers
djay does not have a separate volume control for the FX themselves. It is essentially linked to the volume of the song you are apply the FX to.
