I’m new to the forum, so apologies if this has been covered in the past. How can I set each deck’s GAIN, so that it does not auto adjust?
Hi Ron,
Which djay version do you have?
Open “Preferences” from the “djay” menu, go to “Advanced” and disable “Auto Gain”.
I have version 3.1.4
