Does anybody’s tracks slightly clip (redlining) out of the iPad? I know I can adjust the master volume decibels but is there a way to do the same with the gain structure? Or do we adjust each song. I don’t hear any distortion. Just worried about headroom and clipping before even reaching the Master output. Any suggestions?
@DJ_A_Diffrance, you have quite a few options in djay’s Settings>Sound. Personally, I only use Autogain. However, in your case if you think the output is running hot, you might want to consider adding some Output Headroom and enabling the Audio Limiter just in case.
Ok cool. I’ll try to use auto gain. Never tried it before. Thanks.
