Serious problem.
The gain of channel is dead.
When i use the gain in the ipad or in the ipad air2, it does not work.
also it occurs to me that when active the headphones button and choose a song is not PFL, it is automatically inserted into a channel
thank you for your post. Please make sure to update your djay 2. If you are using the latest version of djay 2 please contact the support via support@algoriddim.com.
Thank you,
cheers,
