Scooped a slate 4 4.what id.call cheap $70 currentaptop.wont run serarto lite.past 1.6version. Avx drivers blah blah blah So using.dj pro..now.my.ddj-sb3 supported mostly. The slate isn’t
*** do i have to literally map.all buttons on this slate 4 channel for it 2.use.dj pro?
Virtial dj works but i am NOT A fan too un user friendly fat as.im concerned. Any ideas.appreciayed
Hi @Steve_Cavarello, welcome to the Community! This hardware is not natively supported by djay on Windows, so yes, you will need to manually MIDI map it yourself.
For more info on MIDI Mapping on Windows please refer to the linked FAQ below:
https://help.algoriddim.com/hc/en-us/articles/360014911931-How-do-I-configure-a-MIDI-controller-using-MIDI-Learn-on-djay-Pro-for-Windows
You could also check the DJ TechTools MIDI Mapping page to see if anyone else has already manually mapped this though:
I hope that helps!
Thanks for sharing @DJ_MKB
This is the Gemini Slate 4 controller for two decks, with Neural Mix on the outer EQ knobs for channels 3 and 4. - this is version 1.01 there was an error
SLATE4 - 2 deck.djayMidiMapping (54.8 KB)
