Getting Crossfader back
Hi guys,
Super simple question from a real dj novice but I cannot seem to figure this out. Using a MacBook Air 2019, latest djay pro and a DJ2GO2 Touch - since connecting the controller I’ve lost the ability to cross fade - as I’m really just doing bar and function type djing this was reallly handy and I cannot seem to reinstate it. Any advice would be great thanks!
Cheers!
Ben
Hi @redtama85, welcome the to Community! Please try the following:
  1. Switch to 4 Deck Mode and ensure you do not have the Crossfader assignment set to Thru. It should be set to Left and Right for all 4 decks.
  2. Navigate to the djay Settings>MIDI Devices>SCRATCH SETTINGS and make sure to turn OFF Crossfader Cutting Mode and Invert Crossfader
