I’ve been playing on a party using the visualizer with djpro for mac with separate screens, after about 10 minutes I start loosing control of MIDI because of the delays caused by this glitch. I think you guys should look into into it to correct this problem.
Hey there,
sorry to hear that. Are you able to reproduce the explained issue or are you even able to film the problem and send me the video via support@algoriddim.com?
By the way, which djay version, operating system and Mac are you using?
