- Device model iPad Pro gen 2 (11”)
- IOS 18.0.1
- Version of djay 5.2.4
Had a problem with Automix in Djay, if I Lock Screen the iPad or flick to another app, about 20 seconds later the track playing glitches and repeats as if it’s stuck. The timer still ticks down but the song repeats the bit it’s stuck on. Even when you mix the next song it only resolves if you keep the app open on the screen. Only seems to have done this since latest iOS update. I’ve used djay for 10 years alongside stage Traxx app and never had any issues like this. Makes me nervous for weddings nowplease help.
I have tried removing and re installing app.
Thank you
Hi @Vicky_Davies, thanks for the details about your setup and the issue. Is this issue repeatable? If so, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello! It’s been more than 7 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
