Glitching when moving between apps
Just updated IOS 18.3.2 on iPad Pro.
Music is glitching when moving between apps. Is this an Apple thing due to IOS update or is there anything I can do? Thank you
Well, the truth is that iOS apss (in iPhone and iPad) might not be fully running when they are moved to backgroud when some other app is made active.
That is just the way iOS has been designed i.e only 1 app is fully active and has full acccess to all resources. If the active app requires more resources, the app which are in background might be put in “sleep” mode or totally suspended.
https://clutch.co/resources/ios-app-lifecycle#stages-of-an-ios-app-lifecycle
So it’s gonna be like sound clitch as you describe.
Thank you for that and the link, it makes sense. It doesn’t help me with using DJ app for disco and stage Traxx for singing when it glitches the disco. Seems to happen on Apple Music too so it’s not the Djay app issue. Just frustrating and doesn’t seem to be a way to resolve :see_no_evil:
Yeah… that’s the resriction on iOS.
The solution is MacBook :slight_smile:
