Global Effect Routing When Using External Mixer
Problem:
When using djay pro with an external mixer and the DVS feature, there is currently no way to apply a global sound effect to the audio signal.
For example, I am owing a A&H Xone:43C where audio channel 7-8 are routed to the channels effect (dry/wet).
Solution:
I would like to request a new feature that allows users to set a global sound effect in djay pro. This feature would receive the audio signal from the effect channel on the external mixer, apply the selected effect, and then return the output to the return channel on the same effect channel.
Benefits:
This new feature would greatly enhance the creative possibilities for DJs using djay pro with an external mixer and the DVS feature. It would allow for greater control over the overall sound and would simplify the process of applying effects to the entire mix. This would make djay pro a more powerful and versatile tool for DJs of all skill levels.
