Best controller for djay pro on iPad? I’m just starting out but I’m looking for something reasonable priced but also quite advanced thanks guys
I use a reloop mixtour, works like a charm, sounds good. Only flaw for me that no pitch is available only auto sync
I use the Reloop Mixon 4; it’s the best controller for day Pro especially if you have an iPad Pro 12.9 like i do. But it’s $800. Check out the Pioneer WeGo series if you’re just starting out. I started with the WeGo 2, you can find them for $200ish.
The Wego is a sick little piece of equipment. Small, sturdy and has everything you need to start out. The best thing…it’s Pioneer, so the knobs, sliders and jog wheels are on point. Highly recommended. Works great with IPad and DJay Pro. Just wished I could use DJAY Pro 2, but not compatible with ipad yet…ugh. Wego is the way to go if you don’t want to drop a load of cash on your startup.
