Having an issue removing a grey que point. The standard que point is white, then blue, green, and red. The issue is when playing this particular song during an auto mix djay2 wants to transition to the next song at this point which is 22 sec. In the song. See right deck.
Hi Robert,
if you are referring to the white “Set” cue point, this cue point won’t be stored and is only set for the session. So once you set it, you can change its place by using the “Set” button underneath the jogwheels.
I hope this helps to explain things.
