Grid Edit "Anchor" Broken on 5.3 and 5.3.1
  • Device model - MacBook Pro 16inch 2019
  • Version of operating system - Ventura 13.7.4
  • Version of djay - 5.3 and 5.3.1
  • Hardware/controllers used - DDJ SX2 also offline mode
when trying to edit grids using “Anchor” it does not react or do anything, this only happens on the 2 new versions of DJay pro 5.3 and 5.3.1
But if you use it on DJay Pro 5.2.10, this works flawlessly without any issues.
Ive tested this and these are my results.
I used, Lady in Red - Chris De Burgh, this is a hard track to warp so you need to put Anchor points to set the grid straight.
Hi @eecy_cee, I tested this on the macOS version of djay 5.3.1 and was not able to replicate this issue. Can you please share a short video of this that I can pass onto engineering to see if they can replicate it? Thanks!
Hi Slak_Jaw thanks for responding, I’m pretty sure this was an issue, I’ll do a video, will post soon:)
I’ve replicated the issue again Im just doing a video now
