Hi :
I can’t see shortcuts for beatgrid , do we have ?
A shortcut? Do you mean a MIDI mapping?
Midi or keyboard shortcut
Hi @Mauri_Moore, there are several Keyboard shortcut options for beatgrids on macOS.
- Simply set the Target to Deck 1, 2, 3, or 4 as needed then
- In the Action section scroll down to the BPM/Grid Edit section.
this doesn’t answer the question , Shift Downbeat Left or right does not move the grid in small steps .
Thanks anyway
Your original question said nothing about fine increments.
yes , sorry . I want to do small changes in the grid .
