Device model (e.g. 2020 iPad Air 4th Gen):
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question/suggestion/feedback
I have a big problem related to the AlphaTheta GRV6. I updated the firmware, the software, and Windows, and since then nothing works — everything is messed up. I’ve been trying for three days, searching all possible websites to find a solution, but nothing helps. The program doesn’t recognize the controller or the laptop, and when I finally get it to recognize the controller, I can only play sound through the laptop speakers.
Alternatively the latest build of VirtualDJ has a tick box option to disable MIDI 2.0 so you can literally just install it and tick the box. Problem solved.
The option disables MIDI 2.0 regardless of what software or hardware you use.
Using this method does not require you to uninstall anything or disable updates.
Hi again @Blazo_Crnojevic, we have created a how-to video for restarting the MIDI service on Windows. This has also been added to our main Help Center article:
Hello everyone, we released a supplemental update to Windows djay 5.6.4 on April 10 which should fix the issue where MIDI controllers are not detected. We added a small workaround which should ensure that the Windows MIDI Service is started on app launch. I hope that helps!
