iPad Pro 11-inch 1st Gen
iOS 17.4.1
djay 5.1.4
Reloop Buddy
Quick question - if you edit a ‘Built in’ map you appear to lose Hardware Mode. Is there a way to re-enable it or is it only for the built in maps?
iOS 17.4.1
djay 5.1.4
Reloop Buddy
Hi @MP1,
Hi again @MP1, also make sure that you custom MIDI mapping has a Crossfader mapping in it. This is a requirement for Hardware Mode.
Aha - that’s the problem!! I deleted the crossfader mapping! I don’t use it and sometimes knock it off centre as the Buddy is pretty cramped.
Is there another way to disable it? I couldn’t find anything in the settings.
Could I map it to a non-existent fader, ie. Make up the midi details?
@MP1, here are some options:
Thru in 4-deck worked a treat. I switched in back to hardware mode and the crossfader was effectively disabled.
Thank you for your help.
You’re welcome @MP1. Glad that worked for you.
