Please can you support this, it’s in the djay1 mac app! Just bought an ipad mini and the djay2 app is great so far but that’s a tool i used all the time and i was expecting it. Well done on the app and please consider this feature!
This is not supported at the moment.
Good News: Harmonic Match is now available on djay 2 for iPhone on an iPhone 5S.
i reallly dont think thats possible unless you have a key changer plugin/fx of some sort if i come across something i will let you know .
Can you please support it asap, thanks
