Has anybody used a handheld gaming PC with DJay?
I’m going to be picking up a Lenovo Legion Go, which runs Windows for some long plane rides. On takeoff I always like to spin a few tracks on DJay using my phone. Wondering if anyone has done this and has any insight on how to set up controls for the buttons/analog sticks, ect. Apologies if this is the wrong section of the forum!
If not, I’ll dive into the rabbit hole and report back!
I have Roger Ally - I’m going to use it but I haven’t even tried to install the program on it yet. If I do something, I will share my experience
I’m going to be picking up a Lenovo Legion Go, which runs Windows for some long plane rides. On takeoff I always like to spin a few tracks on DJay using my … I’ve been putting together an ultra-portable DJ setup. The concept is simple - be able to put on a party with stuff I can fit inside a hand luggage-size bag. DJ software can be used with a DJ controller device to mix audio files on a computer instead of a console mixer. DJs may also use a microphone to speak to the …
I installed a few programs for my ROG Ally which is similar to your Legion Go. I think that with this pixel density on the screen, navigating by touch in programs on the extended visualization is difficult. In the automix option it is easier because we do not have a large number of manipulators. I do not know how to remap the action to the knobs and buttons - I have an armory crate which is used for settings but I did not find such options - maybe the solution will be some program to emulate a virtual joypad.
I connected my Traktor Kontrol controller. Navigating is easier using the manipulators from the console. The advantage is that I do not need a large laptop, I do not recommend sending the master sound via Bluetooth, too much delay regarding the jack connection from the console to the monitor.
Has anybody used a handheld gaming PC with DJay … I’m going to be picking up a Lenovo Legion Go, which runs Windows for some long plane rides.What sets them apart from traditional gaming consoles is their versatility. Handheld gaming PCs allow you to play your favorite games wherever you are, whether you’re on the bus, in a coffee shop, or just lounging on the couch. One of the biggest advantages of handheld gaming PCs is How good is a $1,000 gaming PC? Are gaming PCs under £1000 any good? Absolutely! Our gaming PCs under £1000 deliver high-end performance, capable of running the latest games at impressive settings while leaving room for future upgrades and if you’re looking to start streaming, these systems are a good entry point.
I hear you touch navigation on these high-PPI handhelds really is a pain, and remapping buttons on Armory Crate is pretty limited. Using your Traktor controller sounds like the cleanest workaround, and yeah, Bluetooth audio lag makes it unusable for mixing.
I’m currently using a Reloop Mixon 4 with an Android Google Pixel phone, an Asus Rog Ally, and a Microsoft Surface laptop. All connections are wired. Once you master navigating with the controller, the devices are just a platform for DjayPro. My only wish is for greater support for Android and software developed to match iOS standards.
