- Device model: Macbook Air M3 2024
- Version of operating system: 15.1
- Version of djay: 5.2.5
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): None
Your question:
Any way to have shortcuts perform multiple actions in sequence?
In some situations I need one button to do multiple actions sequentially. For example: in other software I use the “K” button to make the active deck match the bpm and then enable keylock. This speeds up my live mixing process a lot.
Another example: with the “T” button I activate the pause button of the active deck (generating a brake vinyl effect) and immediately activate the instant reverb (or other) effect.
Any help would be appreciated.
