If Djay had the ability to create tracks (when the cross fader goes completley over) that would be great. I Djay in a club and its a pain to have to use adacity to track a 5 hour mix. If DJ had the ability to create a new folder and tracks mixes that would be great!!!
Hi Andrew,
Do you mean track markers so you can split the mix into separate tracks?
Yes, that would be excellent, because we can make 5 hour long mixxes. And just troublesome and hard to move the slider to a particular point to go back to a section.
