HDMI Noise hum when connecting HDMI cable on iPad+ Beatpad 2
Anyone experiencing noise hum when connecting a HDMI cable to sendo video through iPad Pro+Beatpad2 Audio Out?
When the HDMI cable is disconnected the noise disappears.
What could it be?
Hi @tchesco,
Thanks for sharing your HDMI issue.
This is not something we have seen too common as of recent but we are interested in getting a bit more information from you regarding this issue if possible.
So that I can better assist you, could you please answer the following questions:
  1. What model iPad Pro are you using?
  2. What version of iOS are you running?
  3. What version of djay are you using?
  4. Is this issue easily reproducible?
Hi Nathaniel,
Thanks for your reply.
  1. iPad Pro 2018
  2. 16.4.1(a). The latest
  3. The latest.
  4. Yes. Everytime the HDMI cable is plugged on the switch adapter the noise hum begins. When the plug is disconnected it immediately stops.
    I tried with 2 different switches and cables, the apple original (USB, HDMI and AC power), and an alternative one. In both happens exactly the same.
    Thank you for your concern,
Pedro
