i just bought djay2 for iPad and it’s more than great!I used virtual dj with my laptop and my hercules console but now i left them all behind with my iPad mini(16gb)and djay2 and griffin splitter cable!i have an issue and i don’t know if my settings are wrong or that;s way it works.
when i’m mixing in my headphones i listen to the new track.1-2 seconds before complete the mix in my headphones automatically listen to the ending track and it;s a little bit confusing.
does anyone know why this happens?
thank you
Yeah!that’s it!thank you very much for your quick and right solution!!!
You are great guys!!!
Hi John,
I’m not sure if I understood you correctly, but maybe this will help. Tap the gear icon, go to “Advanced” and turn off “Auto-Select” under “Pre-cueing”.
