Help needed setup Reloop RMX44BT + 2 XDJ 700 + iPad Air
As indicated need help to setup Reloop RMX44BT + 2 XDJ 700 + iPad Air with lightning + Djay Pro Ai, connecting cables that i need… all the info someone could give. The mixer as Bluetooth but i prefer cable connection.
I appreciate some step by step tutorial or a YT video, i will have a gig at the end of the month and can’t do a checksound before.
Thanks in advance,
Hey @Marcio_Reis,
Good to see you back in the Community again!
Unfortunately, neither the Reloop RMX44BT nor the XDJ 700 are compatible with djay Pro AI for iOS devices :pensive:
You can check out the list of all compatible devices via the link below:
Once you have a compatible controller or mixer for your iOS device, you can connect your device by following the steps in either of the links below:
I apologize for the inconvenience and hope this helps! Feel free to reach out if you have any further questions. Have a nice day!
