Help!!! Pioneer DDJ We go 4 controller not working with IPad Air- Djay app
As above. My Iphone has the Djay app downloaded and works fine with controller. My old Ipad also worked fine.
I’ve bought a new IPad Air (Refurbished) and this is not syncing with controller.
What can i do to make this work? If I download DJay Pro would that be compatible?
Thanks,
Josie
Hi Josie,
Which exact devices were you using and which iOS version are the using?
Do you connect all devices in the same way?
Thanks for your reply.
I am using the Pioneer DJ we go 4. I’m using the Ipad Air.
Yes I connect my Iphone the same way which seems to work?
Thanks,
Josie
