- Device model MacBook Air M1
- Version of operating system *(e.g. macOS 12.6.5
- Version of djay 5.17
I recently upgraded from djay Pro 4 to djay Pro 5 on macOS, and I’m struggling with a few changes, hoping someone here can help me out.
- Automix Transition: In djay Pro 4, I was able to easily choose the transition for Automix from a menu/dropdown. However, in djay Pro 5, it seems like I have to go into the settings to change the Automix transition. Does anyone know of a quicker way to change the transition without diving into the settings every time? This change is really messing with my workflow.
- Crossfader FX: Is it just me, or is it not possible to use the crossfader FX while Automix is on in djay Pro 5? I used to rely on this feature quite a bit and can’t seem to figure it out in the new version.
- UI Changes - Missing Arrows: I’ve also noticed that the arrows between Deck 1 and Deck 2 are gone in my UI. These were super useful for me, and now I can’t find them. Did they move them somewhere, or are they removed altogether?
I really hate it when an upgrade messes with the workflow I’ve grown accustomed to. Any tips or workarounds would be greatly appreciated!
Thanks in advance for your help!
