Hercules 200 iOS FX buttons with no function
I use the Hercules inpulse 200 with the iOS app and most things work pretty great. Nonetheless I do not get the FX buttons on the controller to work. When I press nothing happens. Any idea how to fix that? It would be great if I could just start and stop FX with those buttons.
Best,
Bastian
Hi Bastian,
Thanks for posting in our Community.
What button are you referring to? The 4 pads below the HOT CUE and ROLL button?
  • You can get to the FX by pressing SHIFT and HOT CUE. These are the instant FX of djay.
  • You can get to the SAMPLER by pressing SHIFT and ROLL.
Please note that you can customise the mapping of any MIDI controller. Just follow our MIDI Learn guides on iOS:
https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-configure-a-MIDI-controller-using-MIDI-Learn-on-iOS-
https://help.algoriddim.com/hc/en-us/articles/360016060800-I-already-mapped-this-controller-on-my-computer-Can-I-use-the-same-MIDI-mapping-file-on-my-iPhone-iPad-
I also encourage you to visit this thread, it has a lot of valuable information:
https://help.algoriddim.com/hc/en-us/articles/360014513500-How-do-I-MIDI-map-djay-Pro-AI-s-Neural-Mix-controls-
Let me know if you have any further questions.
Cheers, G
Hi Guillermo,
thanks for the info. Those are the buttons I am refering to and I already tried it with shift and hot cue (hot cue button flashing then). Nothing happend.
I will give it another try and post my results here.
Best,
Bastian
Hi Guillermo,
I checked the Learn MIDI feature and found out that the FX buttons are not mapped by the default profile (see screenshot). Is it possible to update the standard profile as I am not able to change the MIDI config because I am testing the App in free mode?
Best,
Bastian
Hi Basti,
Thanks for pointing this out. I’ve reported the missing instant FX in the mapping to our developers and they’ll look into solving this as soon as possible. I’ll keep you posted with any updates about this.
Cheers, G
Alright thanks, I am looking forward to it. :+1:t3:
We wanted to share with you that this issue has been fixed with the latest update to djay Pro AI for iOS (version 4.0). Please update your app when you get a chance on the App Store, and the FX should work as expected now.
Thanks for your patience, and happy mixing! :headphones:
