Hey there! I’ve just bought the DJ inpulse 200 and I’m using an iPad 8th generation running on iOS 18.1.1. I’ve connected the iPad to the deck and I’ve downloaded the Djay app (5.3.1) The app works perfectly but I cannot control anything with the deck… I don’t know if I’ve done something wrong but all the buttons from the decks are lighting up. Can you help? Thanks!
Hi @NISA, welcome to the Community! Sorry to hear you’re experiencing this issue.
- Can you please confirm if you have the original Inpulse 200 or the Inpulse 200 MK2?
- How exactly are you connecting your iPad to the Inpulse 200? Since your iPad has a Lightning connector, are you using any adapters or special cables?
- I highly recommend that you use a genuine Apple Camera Adapter: Lightning to USB 3 Camera Adapter - Apple
- Please also make sure to connect you original iPad charger and cable to the charging port on the camera adapter and confirm that you iPad is charging normally when connected.
