Hercules DJControl Mix — djay 5.6.7 MIDI mapping
This is my personal mapping for DJControl Mix. Three behaviours differ from the (built-in) mapping, and each is marked (Custom) in the table below:
- SAMPLER pads → Neural Mix Mute, SHIFT for NM Solo.
- Loop lengths → 8 - 4 - 2 - 1 beats, SHIFT for 1/2 - 1/4 - 1/8 - 1/16.
- FILTER/BASS knob, Bass Mode → Neural Mix Vocal level instead of a Low EQ.
| KEY | ACTION | SHIFT (SECONDARY) ACTION |
| U USB | USB power/data | — |
| S SHIFT | Hold for secondary actions in the SHIFT column. | — |
| 1 CROSSFADER | — | — |
| 2 FILTER / BASS | Bass Mode: Neural Mix Vocal EQ (Custom) | — |
| 3 VOLUME | Deck channel volumes | — |
| 4 FILTER / BASS MODE | Toggles FILTER/BASS Mode knobs. | — |
| 5 SYNC | Sync | Tempo Reset |
| 6 CUE | Sets a temporary cue point when paused, or returns to it when playing. | Jumps to track beginning |
| 7 PLAY | Play/Pause | Automatic transition to Left/Right deck. |
| 8 JOG | Vinyl Mode On: Scratches. Vinyl Mode Off: Nudges | Track scrub |
| 9 TEMPO | Tempo | — |
| 10 MONITORING | Headphones pre-listening. | Left (CUE MASTER): Toggle Cue/Main mix. Right (SPLIT ON/OFF): Toggle Split Cue |
| 11 MASTER | Master Volume | — |
| 12 HEADPHONES | Headphone Volume | — |
| 13 VINYL | Vinyl Mode On: Scratches. Vinyl Mode Off: Nudges | Slip Mode |
| 14 PAD MODES | HOT CUE: Hot Cues. SAMPLER: Neural Mix (Custom). | HOT CUE: Instant FX. SAMPLER: AutoLoop. |
| 15 PADS | HOT CUE: Set/Trigger Hot Cue 1 - 2 - 3 - 4. NEURAL MIX (Custom): Mute Drums - Bass - Harmonics - Vocals. INSTANT FX: Instant FX1 - FX2 - FX3 - FX4. LOOP: AutoLoop 8 - 4 - 2 - 1. | HOT CUE: Clear Hot Cue 1 - 2 - 3 -4. NEURAL MIX (Custom): Solo Drums - Bass - Harmonics - Vocals. INSTANT FX: Instant FX5 - FX6 - FX7 -FX8. LOOP: AutoLoop 1/2 - 1/4 - 1/8 - 1/16. |
