**Summary of the issue:**split output does not function . master and cue volume comes out both end of split cable provided. Works fine on MacBook because it does not require a usb adapter. But with the iPad I have to use a usb adapter which makes cueing impossible.
How to reproduce the issue:
As described in problem
Hi @Five-0, please note that there is a difference between Split Cue and Split Output. Please confirm which one you are talking about - it sounds like you are talking about Split Output. See below for a detailed explanation of Split Cue.
Split Output is for using a DJ Mono Splitter cable to split the stereo headphone socket output of your device into a Mono Master Output and a Mono Headphone Cueing Output.
Thanks for clarifying @Five-0. I have changed the wording in your original post accordingly. With your headphone splitter cable connected, can you please share screenshots of you djay:
Hello! It’s been 2 weeks since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
