Not or Now? It’s listed as supported on the Algo’s website.
I’m asked to recommend a controller and am wondering if the Impulse 500 is a good choice. The fact that it has AUX so that a Bluetooth can be plugged in. It also has a Mic in, which is also welcome for the specific use case.
The built-in audio interface in Reloop Ready & Buddy does not sound great, so I would avoid. The Impulse 500 is in the same price range, but am wondering if it sound good?
I have had the Inpulse 500 since 2022 and still consider the controller to be a good choice, especially in comparison with the devices that are otherwise recommended in this price range, e.g. the Flx4. I’m not happy with the standard mapping and have customized it extensively, but of course that’s something everyone has to decide for themselves.
I can’t complain about the sound, but I also use an external mixer independently of the controller, so I don’t go directly to the PA with the controller.
Good morning I am trying to connect my Hercules impulse 500 to my djay app and I am in need of help I see where it says for Bluetooth controller but mine is plugged in and the mapping I see you have that figured out too please send me any information you can i would be greatful have a blessed day
Hi @Franklyn_Wilson, welcome to the Community! Please provide more details about your setup:
Hardware Firmware Version:
Are you using the free version of djay or do you have an active Pro subscription?
Please share photos of how exactly you have everything connected to your device.
Please share screenshots of your djay Settings>Audio Devices and djay Settings>MIDI Devices. Thanks!
Hi again @Franklyn_Wilson, @Armigo is correct, this device is supported on all versions of djay except Android. If it’s not working by simply connecting, please answer my question above. Thanks!
It’s not quite complete. In particular, the filter button works differently, as does the effects section. But you can still customize it to some extent using MIDI mapping to suit your preferences.
Hi @John_Matthess, yes the Inpulse 500 is a supported device and can be used with the free version of djay. Please, note however, that not all djay functionality is available in the free version. Please see below for a detailed feature comparison between the free and Pro versions:
