The Ability to use the Hercules DJ console Mk.4 With DJay for iPad using USB Camera Connection Kit to control the software, currently it only works as a sound card, so this wold be a nice feature to have.
The ability to use the MK2 would be good too.
MK 4 on iPad YES! Please
Is Djay Pro now enabled to run MK4?
Do you work for Hercules?
Work for Algoriddim?
Never say never!
HERCULESE never promised the controller would support Djay.
ALGORIDDIM never promised their software would support Herculese.
You have to BUY A CONTROLLER that is officially supported because it is NEVER GOING TO HAPPEN.
Any update on MK 4 on iPad?
