i have an old iPad Air with both the DJay 2 app (DJay AI) and the Djay Pro app
Hercules Starlight with DJay Pro
I connected the Hercules starlight and opened the DJay 2 app (DJay AI) and it works perfectly. But when I open Djay Pro it doesn’t work at all. strange.
any ideas? what should I be looking for in the settings menu? under MIDI it says “Found 2 devices” but does not show me the devices. When I press rescan for midi controllers nothing happens
Hi @John_Viera, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
DJay user since 2011.
thanks so much for your help
You’re welcome @John_Viera. So is your issue resolved? If not, please share the requested details above about your setup. Thanks!
