hi guys i got ddj rb. i can't use headphones
i try to use headphones with my ddj rb connect with ipad pro then it can’t use headphones. when im put it. it have just fizzy sound but controller still can use so program not supported or im connect wrong.
i just wanna use headphones together with speaker. pls :pray:t2:
sb2 can connect or not? and rb not supported on ipad right?
im buying already (ddj sb2)
There’s a list of all compatible controllers on the main Algoriddim site (DJ Gear).
Hi @Apilak_Prasongsirisa, welcome to the Community! Please note that the DDJ-RB is only supported for djay on macOS and Windows, not iOS. I’m pretty sure this hardware is not USB class compliant so it cannot be used with iOS devices. The DDJ-SB2 is, however supported on iOS. For a full list of supported hardware for all OS’s please see the linked page below. I hope that helps!
