So having used the djay for ipad I decided to buy the pro version for windows using my wego3 controller but I’m not finding any way to assign keyboard shortcut for the hi/low pass filter. Any ideas?
You shouldn’t have bought the pc version, it is the only version that sucks very hard of Algoriddim and the filter does have a severe issue, if you do it with a noisy song it will sound very harsh in the start.
I need that tooo!!!
