I’m using DJ Pro to DJ with Spotify.
The CPU goes very high even when idle (30%). So the CPU fan goes crazy after 1 minute of using.
Has this been solved?
I’m using Macbook Pro Retina with 2,5ghz intel core i5, 8GB of RAM operating system Sierra 10.12.5.
Exactly the same issue. No action taking place. CPU usage at 15% (top of the line MBP Retina 15"), gets hot.
My Mac has always run hot and Strong fan noise when using Djay.
I just thought that was normal, Runs good though.
Hey Ricky,
I’m sure you will be asked technical stuff.
I.e. Os,ram, which MacBook, etc.
Hey there,
thank you for your feedback.
Are there any processes running in the background while you are using djay Pro for the Mac?
Hi, no other process are running in the background… CPU goes hot after 5 minutes of using.
Here’s a screenshot:
i’m having the same problem, 30% CPU when idle. Could you please solve this?
Kind regards
no, CPU level is normal until djay Pro starts.
Kind regards
I would like to confirm that I have this exact same problem.
No other apps running in background
DJ Pro 1.4.3
Yosemite 10.10.5
Model Name: MacBook Pro
Model Identifier: MacBookPro10,2
Processor Name: Intel Core i5
Processor Speed: 2.5 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 8 GB
Hi I noticed that it heats up and consumes a lot of battery because it uses in my case the video card Amd and not the one integrated in the I7.
I just purchased DJ Pro 2 for my MacBook Pro. When DJ Pro is running, the CPU usage skyrockets and basically renders the entire MacBook unusable until you exit DJ Pro.
No other programs running in the background.
Hola y alguna respuesta a este problema?
