HIGH CPU USAGE & HIGH TEMPERATURE IN MY Mac Pro
After the update to version 1.3.1 my mac when i open djay pro goes really HOT!!!
and the fans work at full speed .
When i close djpro everything goes back to normal after few minutes (usually one or two)
In the past with previous versions of dj pro never had temperature problems
Yessss!!! Sucks because my Mac crashed in the midst of spinning
Hi guys,
thank you for your post and we are sorry to hear that.
Can you tell us which macOS and devices you are using?
Thank you in advance.
Ι have a mac book pro
I use mac os el capitan
