High/mid/bass controls ddjwego4 &idjpro
Is it possible to set the ddjwego4 controls for high/bass/filter into standard high/mid/bass? I’m using iPad Air and algoriddim djpro.
Thx!
Yes! When connected to the WeGo4, a new setting will appear in the preferences menu. It seems this changes something in the WeGo4 firmware rather than being just a software setting, so you might possibly have to select that every time you power up the device.
