On Djay Pro 4.1.5 on a 2019 MBP running iOS 12.6.3.
Hot Cue trigger is not quantized when in an active loop. I hope that makes sense. In other words, if I am currently in an active loop and I want to jump to a hot cue that is outside the active loop section. I have quantize ON. I would expect to be able to trigger the hot cue a little bit early and have it jump at the next beat (i.e. quantized). However, this is not the case. It jumps exactly when I trigger the hot cue. So, not quantized.
I’ve noticed this behavior for a long time, perhaps as long as I’ve been using Djay Pro which is since v 3.x.
