Hot cue.
i am using a wego 3 and djpro, once i have saved a hot cue from a track is there a way of using it (saving it) with out having to load up the track it was saved from?
Hi Stephen thorpe,
so you want to play a part of a song which is not loaded?
Have you tried using Samples to do so?
pretty much lukas. my problem is i have saved certain samples from tracks but can only use them if the track is loaded onto the deck (jogwheel). how do i save my samples and then use them in my sample options because when i open the tab there is only the samples that come with djpro and nothing i have saved.
