Hot Cues in vertical orientation on iOS
YOUR SUGGESTION:
  1. Option to display hot cues in vertical mode in iOS
  2. Option to hide jog wheel in vertical mode to get more space for other things
Hi @DjSasha_DelhiDevils, this is already possible on iOS on both iPhone and iPad if you switch to Pro Mode instead of Classic Mode:
Yes just checked it’s for only single deck at a time so can’t mix the other song in vertical mode
Sorry again checked it have to click on the deck no.
To have the hot cue view issue solved
Thx
You’re welcome @DjSasha_DelhiDevils
