Hot Cues with Integrated Loops:
YOUR SUGGESTION:
I suggest the addition of a feature that allows saving a Loop as a Hot Cue. Triggering a pre-defined loop immediately upon hitting a cue point is a critical tool for creative transitions and rhythmic stability.
This is already possible @djdeklame. Simply enable a loop then press a Hot Cue to save is it as a Cue Loop.
