Hey,
Does anyone know if there is or if you can set a hot key to load a video only with no sound onto a deck that already has an audio track loaded to it?
I find the drag and drop to do this a bit fidgety in the club and I’ve found myself accidentally dropping the video onto the video+audio drop zone instead of the video only drop zone, which means you lose the audio that was playing - very embarrassing.
I’m using djay Pro 2 on a MacBook Pro with a Pioneer DDJ-SR2 controller.
Billy
