Any way to map keyboard keys to hit specific FX functions? Fully mappable options would give every user alot of flexibility for their own ergonomic use.
Hi @Joe_Miller,
Assuming you’re using djay Pro AI for Mac, have you tried editing the keyboard shortcuts in djay’s Preferences > Shortcuts menu? I’ve included a screenshot below for your reference.
If you’ve already tried this, but it doesn’t quite fit your needs, could you explain a little more about the specific FX functions you’d like to map to keyboard keys using djay? Thanks in advance!
