HOW ABOUT MAKING AN UPDATE GIVING THE OPTION TO VIEW THROUGH A WIRELESS HARDDRIVE ON IOS.
Guys I love my iPad but we all know for the ppl who can afford only the basic model is only 16gigs, could you give an option to where you can receive your music from? I looked everywhere and I couldnt find the best method to get music wirelessly to work with iTunes, all I want is to use your app and use a wireless harddrive (fyi most wireless hard drives have an app to use stream media) so hat I can precue songs and play them if I’m digging the mix, also a notification that I played that song already and have it reset notifications when I close the application but if you can update this for IOS I would be so happy (Southpark), thanks!
thank you very much for your post.
There are several options in order to import songs which are not stored locally on your iOS device.
Please check out this FAQ entry i uploaded and it would be great if you could feedback about the entry.
Thank you in advance
http://help.algoriddim.com/customer/en/portal/articles/2298814-accessing-the-%22my-files%22-section-
Hi Fernando Ter,
every app is supported which has the “Document Provider” App Extension, please contact Verbatim to see if they do.
verbatim media share…is compatible?
